Do I Have To Split The Cases On A 348 Cota
parky265
Replacement of the crankshaft seals does not require that the cases be split. Just remove the flywheel on one side and the clutch drive gear on the other side to gain access to the seal carriers.
Previous advice on removing the drive gear is correct. It is a tapered fit to the crankcase and requires a good fitting puller. Don't bother with heat as the gear and the crankshaft are both steel and will expand at the same rate. Tighten the puller and give it a couple of goods raps with a hammer. Retighten and hit it again, then retighten and hit it again. Repeat until it comes loose. If you have access to an impact tool that may help.
