What's The Difference?
The welding on the Godden frame, may not be the prettiest, but the frame is functional and strong, plus it's resistant to flex, which the TY175 suffered from
I may be wrong but from distant memory wasn't the Whitehawk 175 an attempt at making the adult sized TY175 a little smaller ? I'm sure it had a lower stand over height.
The Whitehawk 80 and Whitehawk 175 then effectively filled the gap between a std TY80 and 250 Majesty.
The Majesty 175/200 frames are very different to those of the 250/320
the swing arm pivot is behind the seat tubes on the smaller bikes & in front on the larger ones, also because the 250 engine is so much bulkier than the 175 the overall frame dimensions are greater
the front forks are of a greater stanchion diameter, think the wheel hubs are the same though
I know of one small Majesty (it was built for & ridden by John Shirt Jnr) that has TY250 mono forks & wheels
I suppose these could be added to any Majesty but not so sure about those weird z spokes though on the mono wheels
