Ty250A Exhaust Cleaning
Is there a good way to clean/flush the mid section on my TY250A ? It seems pretty mucked up and I thought about trying to flush it with diesel fuel.I don,t know if there is any packing material in there that might get ruined by anything I might use to flush it with.If so,then is like a Sherpa exhaust where you have to cut it open to properly do the job?
I burn mine : I put a little gas in and light up with a torch, once the fire is started, I leave a bit of oxigene whit a bit of air from the compressor and let burn. If the combustion is right, you can '' follow '' the the red patch all along the exhaust. I have to tell you that it's not the thing to do when a neighbor is out on the patio whith friends, it make a lot of smoke. Another way to do the job is to put the exhaust in a fire and let burn.
Guy
