Ty175 Fuel Mix Help Needed
davdeborg
hi
currently running my ty175 at 50-1 on good quality castrol 2t fully synthetic oil
just think it smokes a bit to much been reading forums and people are saying anything from 50-1 to 100-1
with a good quality full synthetic 2t oil.
any suggestions of a good ratio mix bike only rode off road any help greatly appreciated as neighbours dont like the smoke
would it be ok at 70-1 with castrol fully synthetic oil
cheers guys
Edited by davdeborg
Hi I mean the whole exhust. i started a fire in a big steel drum and put the exhust in the fire and let it burn overnight. Do not try it this way if it's alum. If you get the exhust good and hot like after a long long ride and it still smokes after you shut the motor off then it's oil build up in the exhust.
cleaned whole exhaust soaked it for five hours in a red hot caustic bath all clean now no excessive smoke its perrrrrrrrrrrrfect
also cleaned the insulation in tail pipe as it was dripping in oil
so all sorted
cheers
