gazzaecowarrior Posted May 12, 2013 Share Posted May 12, 2013 I found it a struggle many years back when I had a Rev 3 250 to screw and unscrew the right hand exhaust bolt. But on the 125 it's even tighter. My long reach t handle allen bars cant do the job. Normal allen keys cant get near it. Ive resorted to fiitting a hexagon headed nut and using a reverse spanner to tighten it up but it takes ages as you only have about 30 degrees rotation of the spanner. Would a ball headed allen key fit an allen bolt on the right exhaust bolt ? Quote Link to comment Share on other sites More sharing options...
betabonkers Posted May 12, 2013 Share Posted May 12, 2013 I've got the right bolts here and the proper Allen keys. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted May 12, 2013 Author Share Posted May 12, 2013 I've got the right bolts here and the proper Allen keys. Hi Jason. I've got the right bolts too. What type of Allen key have you got ? It is a worse angle than our 250's use to be. Quote Link to comment Share on other sites More sharing options...
