Bleed Back Brakes Evo 300 4T
Is the bleeder valve on the rear diffrent that the front one? It does not look the same and seems to be a tad shorter so when I slip a hose over to trap the air I need to hold it tight to the nut and banjo....thoughts?
Many Thanks
Tom
Sometimes I put a zip tie on the hose when necessary to keep it tight
Great idea...thank you
