August 24, 201313 yr Just wonddering about how many hours you can put on a 2011 Evo 4t 300 before you should cahnge the oil and filter? The Manual claims about 30hrs which seems like a lot. I was figuring around 15 to 20hrs? Also, if it is just practice hours verses an event if that makes any diffrence as you would run a tad faster between sections for an event. Thanks
September 3, 201312 yr 30 would be right if you have quality oil and mostly ride lower-mid revs. If you rev the tits off it then 15-20 sounds right
September 4, 201312 yr a 2 day event= 4 to 6 hours.. 30 hours is norm, after breakin.. i just rode a 2 day event with a 2 mile loop, 11 sections per loop,, 4.5 hours time on the bike...hour meters are cheap..
