September 16, 201313 yr Can anyone help me out with the difference between the AJP "small style" front brake master cylinder and the other posted below? Does small mean the brake lever, reservoir, or thread size for the brake line? Front Brake Master Cylinder Small Front Brake Master Cylinder Assembly Small Style, GasGas Pro Raga, Scorpa, Ossa AJP part number 116.00.820C AJP Front Brake Master Cylinder Front Brake Master Cylinder Assembly Swapping the small Master cylinder for one of these is a popular modification on the GasGas to improve the brake some Beta owners have also swapped. AJP part number 116.00.000 Also know as: AJP BR PMP 28004301 Thanks.
September 23, 201312 yr Find a Brembo with a 10mm piston If you are looking for improvement. You can find them on ebay but make sure it has proper piston size.
