Rev 3 250 Clutch Issues (Done The Clutch Fix) What Next?
Maybe should be in the clutch fix post????
Right, its an 04 Rev 3 250 and when I bought it the clutch wouldn't allow changes into neutral etc so whipped the clutch pack out and have done the clutch fix mod by cleaning out between the lumps and smoothing out the basket etc.
This made a huge difference and it will now shift into neutral while stationary but the problem I have is that it won't release for ages when you first start it and that it sometimes "hangs on" when you pull the clutch in and continues to drive which is bloody frustrating.
It was run on ATF (stands back and waits for the screeches!! lol) so changed on to Putoline light gear oil and after a couple of runs its still no better.
Was thinking of trying the Putoline Nano trans as reccomended by some on here or has the ATF contaminated the fibres?? O r would I be better and buy a new set of clutch plates - and if I do do I still need to "mod" them before installation.
Its the only thing that spoils a bloody good bike.
cheers all.
I did the fix and still use ATF with no problems. The mod should have cured the hanging on in sections, which is frustratingly inconsistent, but the best way to free off the clutch on starting is to hold in the lever, push the bike forward with a foot while putting it in to first. This prevents damage through the sudden force if you don't move the bike. Keep the clutch lever held in and change up through the box as normal. The clutch should free when you hit fourth and be OK thereafter.
I tend to rock the bike in gear before starting it to free off the clutch which isn't a major issue (more of an anoyance than anything else) its the hanging on in sections and inconsistency that is a problem.
Yes tidied up the tabs and yes using 500cc of oil, not tried the master cylinder, how would this show up or what would I check/test?
HoggyF
I wrote this a while back. I re-posted here as you may get some pointers out of it. Cheers..... BillyT
After many years of riding trials it finally happened to me, the dreaded “clutch drag”.
I guess it was inevitable, I had read about, heard people talk about, but never actually experienced it for myself. Can it be real or just a myth? I had read with much respect and interest Dan William’s research and solutions to his clutch dragging issues and read all the testaments to this being the miracle cure.
Being faced with the issue for myself I soon came to realize after all the years of riding trials bikes I have never had a need to really dig in and understand what is actually going on with a trials clutch.
But if I want to cure this dragging clutch on my new 2013 Beta 300cc Factory then I better educate myself on the clutch workings.
Standing upon Dan’s shoulders of the great work he has done it was a good starting point for me.
So you take out the plates and clean up all the glue crap between the fibre steps!
Okay, no doubt this works, but why? Surely there must be more to it than that?
Some people although in the minority have claimed this did not work for them,
Some people use ATF some use purpose made clutch/engine oil all with various results, but why?
So let the research begin.
Lets break clutch drag into three basic culprits:
  • Mechanical
  • Viscous Coupling
  • Physics
  • Mechanical:
The following fall into this category
Warped friction plates
Warped clutch plates
Swollen fibre plates
Notches in the outer clutch basket
Notches in the inner clutch basket
Nicks on the metal tabs of the friction or fibre plates
Not enough travel on the clutch push rods
A race clutch that has tight tolerances resulting in less clearance between plates when disengaged.
The clutch not separating evenly due to machining imperfections
  • Viscous Coupling
For those of you not familiar with Viscous coupling it is basically a fluids ability to transfer motion between two plates a slight distance apart through the fluid itself. It is used on various 4WD systems and machinery.
  • Physics
The viscosity of the engine oil used
The temperature at start up affecting engine clutch oil viscosity
The temperature of the engine clutch oil once the bike is warmed up.
Centrifugal force
Shear of the oil surface between two plates. Vacuum. Surface tension
Excess glue and residue in between the tabs causing the above
So lets clarify some of these things from a technical perspective.
  • Shear of the oil surface between two plates, Vacuum, Surface Tension
If one takes two sheets of glass and places some oil in-between them and the presses them together the next person who comes along trying to separate them by pulling them apart in lateral (equal and opposite) manner will not be able to do so. They will have to slide them apart one surface going up the other down.
This is due to the oils surface tension and the air that was forced out upon squeezing them together has now created a vacuum. Multiple that by several clutches friction plates to fibre plates and one can quite easily see how the potential for a friction plate to stay stuck to a fibre plate is there. What is needed is a surfactant. A surfactant is basically what soap is, it breaks the surface tension on our hands, dishes to let the water actually get to the surface etc in essence making the water wetter by breaking down the surface tension.
But who in their right mind would put soap in their transmission or clutch LOL
2.0 Centrifugal force
Have you ever seen or tried the gyroscopic trick where you sit on a free moving rotating chair, you are given a bicycle wheel to hold at the axle. You hold the wheel upright an assistant spins the wheel and you try to turn it side ways. It tries to fight you and wants to stay upright spinning in its own orbit both axle and radial.
Well a spinning clutch is basically a gyroscope. It is spinning and wants to stay in its own radial orbit. You pull the clutch in, wanting it to separate in the axle direction by basically friction plate’s fibre plates moving away from each other. But the gyroscope effects are fighting it wanting the plates to stay in their own orbit.
Couple that with the above sheer friction of the oil and it is a wonder that plates actually separate at all.
So if your clutch drag issue is caused by surface tension, sheer of the oil, vacuum then Dan’s procedure or ATF is the way to go.
I propose that Dan’s procedure works by reducing the sheer of the oil surface tension, and helping break the vacuum. This is achieved by the filing of a ninety-degree angle when you are filing away the glue and crap. The sharpened ninety-degree angle edges helps break down the oil sheer, breaking the vacuum as each plate is spinning trying to slip against the other and the oil in between. The excess glue build up only adds to the problem by keeping the oil shear and vacuum going. With no distinct hills and valleys it is detrimental to plate separation.
I will also propose that this is the reason ATF works without the clutch mod as it sheer strength and vacuum causing characteristics are much different than regular clutch/engine oil.
And now for the caveat:
How does one know what one of the three basic areas i.e. Mechanical, Viscous Coupling, Physics or combination of all three is the culprit?
Well that's where my experimenting came into play.
Temperatures in the high 80F Dry weather, Sea level. Bike came with Motul engine oil. Changed to Mobile One Motorcycle oil after a few rides. I have used Mobile One for many years.
He is my scenario. With the original Motul oil the clutch dragged. The clutch continued to drag after changing to Mobile One motorcycle oil.
The clutch dragged inconsistently as I was riding it. It was good it was bad all through the day.
In the past with other Beta’s I have owned I could place the bike on a bike stand start the bike let it warm up and put it into 1stgear pull the clutch in and the back wheel would stop or be very easily stopped by placing a hand on it. This was not the case with this Factory 300cc
What I needed was away to logically break this down into which one of the three main areas (Mechanical. Viscous Coupling, Psychics) was causing my issue.
Mechanical:
Brand new bike…. The reality of warped clutch plates or fibre plates hardly likely. Swollen fibre plates hardly likely. Notches in the basket not likely. Other wear or tear not likely due to age of bike (barely broken in).
But until I took the clutch apart I would not know for certain.
Viscous Coupling:
Trying to find out the Viscous Coupling characteristics of Motul or Mobile One was a long shot at best so I put that one to rest.
Physics:
There was nothing I could do about gyroscopic effects.
I was contemplating to dump a bottle of washing up liquid into my Mobile One engine oil. That would surely be a great surfactant it would break down the surface tension letting the plates separate. Okay bad idea! I needed another way to test the surface tension theory. As stated earlier I think Dan’s process works on reducing the shear and surface tension effect so why not try it out.
So off comes the clutch. Checked for all the mechanical potential issues warped disks etc no issue there. Checked out the clutch for Dan’s excess glue etc.
There was excess glue all right but did not really look that bad. But I followed Dan’s instructions, painstakingly removing all traces of glue etc from between the plates.
Re-assembled the clutch pack and re installed. Another 500cc of fresh Mobil One motorcycle oil and fired her up. Got her good and warm and…….. and …….. the clutch was still inconsistent. ****……… now what. Short of calling Dan I proceeded.
What other Physics issue could there be that I can actually control?
I still had the nagging notion that viscous coupling was not eliminated from the equation but I needed a way to test my theory. So why not dump all the oil out of the cases, with no oil in the bike Viscous Coupling would not be an issue and therefore I could verify or eliminate Viscous Coupling as a culprit.
I needed to do this in such a way as not to burn up my clutch or seize my gearbox.
Dumped the oil, put the bike on the stand, started it up revved it slowly, pulling in the clutch to fling off any oil in between the plates, letting the clutch go in a VERY gentle manner as not to burn the plates. Pulled the clutch in, Put the bike in 1st gear let the clutch out slowly. The back wheel started to turn (of course) pulled the clutch in and PRESTO the back wheel stopped turning all by itself. Repeated this several times with constant results.
What the crap I thought! I do have some viscous coupling in this equation.
Now what? I cant run my bike without oil! So it was off to Google to find out what oils for wet based clutches where out there. No motorcycle oil manufacturer out there talks about viscous coupling specs of their clutch engine oil. So it was trial and error. To cut a long story short after testing many different oils I tried a bottle of Castrol 5W 40 RS 4T engine Clutch oil and it did the trick.
I can put my bike on the stand now start it, pull the clutch in and the back wheel stops. The clutch is consistent. I am happy.
But the story does not stop there.
Why is that Mobile One has worked for me all these years and now it does not?
Why is that Dan’s process works for some people and not others?
Here is my take on the whole clutch drag issue.
One has to first determine if it is Mechanical, Viscous Coupling, or Physics at play or a combination of all of the above.
No amount of glue removal will help if the clutch plates are warped or friction plates are warped. No glue removal will help with swollen fibre plates or notched tabs.
However if oil shear, vacuum, and surface tension are at play Dan’s process is the cats meow.
I feel I had two issue on my bike since it is a factory spec bike and the clutch is somewhat changed for this newer model it has a 2013/2014 factory clutch
“A race clutch that has tight tolerances resulting in less clearance between plates when disengaged”. This amplified the oil sheer and vacuum effect and surface tension.
Due to the tighter tolerances on this clutch the viscous effect was coming into play as the clutch plates do not separate as far and the Mobile One and Motul oil viscous coupling characteristics what ever they where contributing to drag while the Castrol Oil did not show signs of viscous coupling.
Dan’s process alone did not eliminate this effect but I am sure if one does his process on an none race clutch or one that has some wear on it will do the trick for you.
So before you trouble shoot your dragging clutch, do some homework and determine if it is mechanical, viscous coupling or physics at play.
So, if your bike does not show signs of drag on the ground, can you put it on a stand start it up put it into gear pull the clutch and have the back wheel stop all by itself?
If so you have great clutch.
Cheers
BillyT
Clutch drag and not releasing when disengaged is not the same issue. Nothing worse than pulling in the clutch and it `works` 1/2 a second after it should. The problem from cold on the first ride of the day has always been around. But the issue of it not working once warmed up can be the master cylinder or slave cylinder. Also is the fluid low? Or it could just be poorly adjusted. If you have the lever adjusted in too far, the piston is not traveling it`s full stroke. Make sure there is some play at the lever. Could be as simple as a rebuild kit for the master cylinder.
As Billy said (Thanks Billy great post) you have to figure out what system is not working.
I would start with backing out the small screw on the lever that actuates the clutch. If this is set wrong the piston in the master cylinder reservoir does not travel all the way back trapping fluid causing all sorts of anomalies.
Edited by billyt
In reply to billyt (was looking for your post but couldn't find it before I posted this)
Backed out the adjuster on the lever and checked/topped up the M/C
Ran the bike up to temp on the stand and in gear to warm everything up and in 1st with the clutch pulled in the back wheel spins and you can't really hold it by hand but in 5th gear you can hold the wheel by hand, if left free the wheel will spin with the clutch in.
Would you suggest trying the oil you used? Or take the clutch pack out and clean more between the pads?
There is a measurement and shim selection listed in the service manual
Not sure why all the effort and discussion and no mention if the clutch was within factory spec in the first place
Hoggy
I known you said it it would not go into neutral and was what started it all off for you, but did it drag before you took the clutch pack out?
Since this is a 2004 and ran on ATF in my deduction it points to the following:
  • Friction plates are warped
  • Fibre plates expanded due to age, type of fluid (ATF) and if you left the ATF wet fibre plates out for several hours or overnight they will have expended due to not having pressure on them as when the do in the clutch pack assembly installed on the bike.
Changing the type of clutch fluid right now is redundant as what ever was in there prior is well soaked into the fibre plates by now.
If the bike is truly a 2004 and still on the original clutch pack then it is due for a new set of friction plates and fibre plates anyway.
I would get a new clutch pack install dry (after doing Dan's mod) and use the oil I recommended or some thing similar of your choosing.
If you do put a new clutch pack in it will still have more drag than a well worn in 2004 clutch pack as it is thicker and tighter but at least you will wear it in correctly and quickly.
As for Triple Zero 7 comment the clutch wear limit I agree will tell you its out which I have no doubt it is, it is the why and solution we are after.
A really good clutch (one that releases and does not drag) can be witnessed by putting it on a bike stand
(after been well warmed up) starting the bike up, sticking it in 1st gear the back wheel will spin pull the clutch in and it should stop turning. This is a tough test and most bikes will not pass it. The highest percentages of bikes will properly
stop turning the back wheel clutch pulled in third gear. What gear does your bikes back wheel stop turning on on a bike stand and in gear with the clutch pulled in?
Edited by billyt
007 - I'll have to pull the clutch out to measure it
Billyt - I can't really remember if it was creeping before I did the clutch mod as it was quite new to me then, but the clutch mod made a big difference to the neutral selection but my memory is that the creeping started after that I think.
As for what gear does it stop spinning, it all but stopped in 5th today.
When I did the clutch mod the metal plates (friction?) were flat when checked on a glass sheet by eye.
Edited by hoggyf
Billy's comments on viscous coupling are very good. I remember being told years ago not to fill the Beta gearbox all the way as it caused the clutch to drag and that the factory guys ran less than the spec oil level. I can also confirm on the new EVO I still have some low speed drag as well as very quick clutch engagement. Certainly quicker than I am used to compared to the '08 which has a clutch "like buttah". Gonna have to get me some of Billy's magic oil. He hasn't steered me wrong yet.
Billy't the castol rs 5w40 has been discontinued now castol say its now power racing 1 5w40 and only available through BMW bike dealers :(
