July 2, 200521 yr Someone set me straight here - The spec sheet says Engine Lubrication 2.5% mixture That's 40:1 What's happening there?
July 2, 200521 yr incase people use a cheap 2 stroke oil? and it covers gas gas a bit sherco recomend 2%
July 2, 200521 yr Someone set me straight here - The spec sheet says Engine Lubrication 2.5% mixtureThat's 40:1 What's happening there? If you look at the 05 bike specs it says 3%.
July 2, 200521 yr Someone set me straight here - The spec sheet says Engine Lubrication 2.5% mixtureThat's 40:1 What's happening there? If you look at the 05 bike specs it says 3%. Ah. Fair do's. It's B*****ks then
July 3, 200521 yr Am i being sceptical here.... but Alloy fork tubes. Met 3 people today who had 05 Alloy handlebar clamps that have broke!! sceptisism or quality control you have a valid point. The chain tensioner on my 05 Raga is too flimsey. The chain is flopping about almost untensioned i noticed today, hopefully it will be a recall part.
July 3, 200521 yr The chain tensioner on my 05 Raga is too flimsey. The chain is flopping about almost untensioned i noticed today, hopefully it will be a recall part. Have GasGas ever had a recall part. The 2002 airbox was totally unfit for purpose in UK. Even dealers recommended replacing it immediately. Recall?
July 4, 200521 yr I do remember getting that rubber free actually - apologies GasGas. You still gave me a year of heartbreak with that 2002 Pro, so I'm sure you can forgive me
July 5, 200521 yr I do remember getting that rubber free actually - apologies GasGas.You still gave me a year of heartbreak with that 2002 Pro, so I'm sure you can forgive me forgiven
July 6, 200521 yr Am i being sceptical here.... but Alloy fork tubes. Met 3 people today who had 05 Alloy handlebar clamps that have broke!! yeah, sounds dodgy I take it Raga, fajardo & shaun morris etc have been using them this year? Hope so! not one of them Gasgas changes without proper testing & then recall all the parts. that'd be s***e. Yeah heard people complaining about the tensioners spud. They should have left them alone after the 04's because they had them sorted then!!
