Gearbox Oil 1999 315R
Hi Chums,
Im looking for a replacement oil for the ELF liquid gold that Montesa spec in the manual. Anyone use putoline?
putoline is fine in it or atf which is a fraction of the cost but doesnt last as long
Thanks nelly1 for replying putoline it is then.
  • 3 weeks later...
ATF for me. It's the only oil that eliminates clutch drag. Used it for 4 years without any issues.
ATF is gear oil for wet clutches.
I've been using Valvoline synthetic Dextron VI ATF for several years and I prefer the clutch action over the ELF oil, very smooth and no drag. If you want sharper hook up use a non Dextron ATF.
The Valvoline Dextron VI oil has viscosity very close to the ELF oil so no clutch drag. other ATF are thicker.
