August 31, 201412 yr I have a knackered big end, not sure how bad it is as I’ve not had the engine running (it has about 0.001” – 0.002” play) Do I need to replace the crank pin and con rod or is there an inner & outer race? And can I split the crank with a 5 Tonne press?
September 1, 201412 yr My cheepie 30 ton press groaned when pressing apart a C15 crank. Edited September 1, 201412 yr by mcman56
