348mate Posted August 17, 2005 Share Posted August 17, 2005 Can any of the experts help me to get the correct air pressure in my air forks? I find that they are very hard to check as the mere action of sticking my pressure gauge on to the valves usually lets all the air out, i know very little air is needed to produce pressure in the forks, but there must be a foolproof way to do this surely???? cheers, S.M. Quote Link to comment Share on other sites More sharing options...
4rtbulldog Posted August 18, 2005 Share Posted August 18, 2005 I have had the same problem when I used my RTL 250S '88 model, it made me not happy to have ride with air forks, replaced with thicker spring spacer and a bit higher viscosity fork oil, pressure gauge is only for air bleeding. Quote Link to comment Share on other sites More sharing options...
g4321 Posted August 18, 2005 Share Posted August 18, 2005 (edited) Use a pushbike pump to add air to the forks (bicycle pump for those heathens South of the border) - minimises risk of blowing seals. Then use a gauge to lower the pressure to the required setting. There are proper pumps made just for suspension - S&W used to make one. Edited August 18, 2005 by g4321 Quote Link to comment Share on other sites More sharing options...
