Right Shox Low Oil
Hi all am new to trials and have a 2007 sherco I'm finding the front suspension hard/minimal travel and adjusting it doesn't seem to make a difference. I checked the oil in the right leg and found it to be quite low would that cause it thanks in advance martin
Low oil level will cause a soft fork.
Restore your adjustment, oil type and oil level to standard as per handbook.
Likely the things are at incorrect levels if they move smoothly otherwise. Levels are 110mm left and 60mm right with left spring removed, forks compressed.
I think, hope that helps!
All sorted now after following a guide I had way too much oil in them Cheers for your help
Splatshop one - took them off and drained oil out and put fresh in at the correct levels
