November 11, 201411 yr Hello, Ive just recently purchased a Beta Evo 200 2013, the chain is looking tired, can anyone inform me of what size chain i need and what makes are recomended. Regards Stuart
November 11, 201411 yr Unless someone is psychic you are unlikely to get a reply, Its probably 520 pitch but length (number of links) depends on sprocket sizes. I like DID chain but if you are making do with old sprockets a cheaper make will probably do.
November 12, 201411 yr If you have the std sprockets fitted I think 102 links of 520 should suit. I buy Regina because it is widely available & both split & half links can be bought. Do not buy a bulky MX type chain they can catch & often do not go through chain tensioners.
November 12, 201411 yr I'm using Regina chain on the Montesa and the Beta. 70 hrs on the Beta and the chain and sprockets are still in great condition. 20hrs on the Monty and still like new. Mags
November 13, 201411 yr Look closely at the chain - the 200 likely has a half link in it. Order the replacement from Beta, less hassle.
