2009 4T Frustration
Normal preferred mix (airscrew) setting on a Kiehin is .5-1.5 range. 2T or 4T makes no difference.
Adjust for best running. If outside that range, a change in low speed jet may be used.
  • Replies 46
  • Views 13.4k
Most Popular Posts
  • I think your final sentence will come back and haunt you? Sherco 4T was a huge flop for the manufacturer although when the bike was running it rode quite nice, the biggest problem they had was the on
  • Chuck it off the nearest cliff & then go get p****d. Sadly you've bought one of the biggest Trials dogs of all time. 4RT as Gizza5 has said for reliability but the 4T Beta is a much better Trials
  • vanman1950
    vanman1950
    Many thanks to all of you who sent me replies both helpful and otherwise. I'm pleased to announce that having put in a new plug as per the manual having first got a spanner that fits from Splat Shop
Thanks Copemech, the bike runs ok ticks over nicely but on removing plug looked rather black instead of biscuit only other thing is has stalled going downhill  a couple of times will try as you suggest.
