Fantic Fm237 Gearbox Diagram
Hi
I'm rebuilding a FM237 engine and I'm having trouble with getting enough of the output shaft through the left hand bearing to allow the washer and circlip to fit on.
Would anybody have a diagram?
I'm tempted to remove the gear cluster but can't see anything wrong.
Could something be stopping the cluster moving over?
I know this sounds self explanitory but wonder if someone has come across this before?
Cheers Michael
Look at the engine diagram on frankfield fantic, it's practically the same as a 240 set up
You may well have a gear in the wrong place
I have just had to walk away and leave it!
I will take it apart tomorrow night and have a look, the crank is fine but the gearbox nips up when the case is tightend.
Something is not right but I cant see it at the minute. Something so simple!!!!!
Thank you for the advice with the website.
