June 1, 201511 yr I'm fairly certain Al the Spanner used to do it on new bikes as part of the PDI when White Bros were one of the UK's largest Trials dealers. Sadly now defunct.
June 1, 201511 yr We should have asked what carb is fitted first perhaps? fast throttle and a keihin should be light enough for anyone. Fast action and dellorto is a little heavier
June 1, 201511 yr We should have asked what carb is fitted first perhaps? fast throttle and a keihin should be light enough for anyone. Fast action and dellorto is a little heavier I've never been brave enough to run a bike with a Keihin on.
June 2, 201511 yr Sorry, I've never danced properly in my life, and certainly not with a flag in my hands :-), but been riding motorcycles all my life and never had wrist ache. Like I said, could be me. Have you ever done the scott? A 40 section road trial?
June 2, 201511 yr Have you ever done the scott? A 40 section road trial? No, but does a 4 day trial count?
June 2, 201511 yr Are you trying to tell me that everybody in the Scott trial has an altered throttle?
June 2, 201511 yr Not if its Sardent. Are you going to tell him the way BigWigg weakens the spring without cutting it or is it top secret?
June 2, 201511 yr years back I bought a Yamaha mono that had a lighter than std throttle, the previous owner had ground the spring down on a grinder reducing the diameter of the wire a bit. worked well.
June 3, 201511 yr Are you going to tell him the way BigWigg weakens the spring without cutting it or is it top secret? years back I bought a Yamaha mono that had a lighter than std throttle, the previous owner had ground the spring down on a grinder reducing the diameter of the wire a bit. worked well. Too late :chairfall:
June 3, 201511 yr If your throttle is heavy get married, You will be surprised how strong your right arm soon gets after a short while!!!
