mrorange Posted July 20, 2015 Report Share Posted July 20, 2015 Can any one please confirm to me the amount of oil in the 2015 Tech front folks as in the manual it states 400ml but this seems excessive to what came out and the manual doesn't quote Tech folks .Thanks Link to comment Share on other sites More sharing options...
topcat Posted July 20, 2015 Report Share Posted July 20, 2015 info on here for seal and oil changes http://www.formula-italy.com/en/product/trial-o39-factory/42 Link to comment Share on other sites More sharing options...
aussiechris Posted July 21, 2015 Report Share Posted July 21, 2015 (edited) According to the 2015 Montesa manual, the Tech forks area as follows Specified fluid (left and right): Tech OJ-01 (SAE 5) Oil capacity (left and right): 400ml Standard oil level (left and right): 50mm from top of tube (Edit: 75mm for the Gas Gas with aluminium Tech forks) The oil capacity shown is after a complete dismantling of the components. You would remove substantially less than that when doing a simple change. The important thing is to set the level correctly. If this is for a 2015 Montesa then you should have got a proper owners/service manual with the bike and it covers both the Tech and Showa forks. If it is for a Gas Gas then this advice may not be accurate as there are a number of different versions of the Tech forks out there. Chris Brisbane Australia. Edited July 21, 2015 by aussiechris Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
