bezaboy Posted August 2, 2015 Share Posted August 2, 2015 What bits are needed to convert a standard engine into a short stroke ? Anybody have contact details for Mick Dickinson, makes heads and barrels ? Quote Link to comment Share on other sites More sharing options...
jon v8 Posted August 2, 2015 Share Posted August 2, 2015 Yup, you need the barrel, a 350 crank, an 86/7mm piston and shorter pushrods. I've bought a new, old stock XT500 piston to build mine with, but others use an XT350 piston. You may need a compression plate under the barrel too. Not built mine yet, its going on the back burner for a while because I'm also building a series 2 Land Rover that I need more than the HT5... I have Mick's phone number at work, which I will pm to you, not at at work tomorrow so it will be on tues. Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted August 3, 2015 Share Posted August 3, 2015 Hi Guy's. Hi Rich. Have you given up on the BSA project then? Don't get like me and have to many in build. Anyway Mick Dickinson on 01709874956 the second person this weekend that wanted his number Ho to be popular . Regards Charlie. Quote Link to comment Share on other sites More sharing options...
bezaboy Posted August 3, 2015 Author Share Posted August 3, 2015 Charlie, Never give up on BSA 's just some take longer to sort Not seen many finished ones rolling out of Chez Charlie, all that time making things for Rio :-( Quote Link to comment Share on other sites More sharing options...
