Project 8X4
Hi Guy's.
Hi Brian.
You don't need to lengthen the swinging arm then, check the wheelbase measurements, and if you get 52 1/2"  you got the old perfect wheelbase.
And we know how much power these little engines turn out, more than a Bantam, and more than a BSA C15.
Should be fun  I need a Video.
Regards Charlie.
  • Replies 35
  • Views 14k
Most Popular Posts
  • A few more photos of the bike
  • A wee change to Project 8x4,I stretched an old bantam frame and used the running gear   from the original project.It's a work in Progress cheers the noo Brian
  • The new and improved 8x4(photo courtesy of Jennifer Charlton Photography)   cheers the noo Brian
Not quite 52 1/2" its 53"  :D .I used an early Suzuki TS swing arm that was on the
original project(I made 2 inserts for the frame and new nylon bushes for the swing arm)
About time you came to one of our trials Brian.
I don't mind swapping you for the Scorpa if you want it tested?
  • 4 weeks later...
Sorry no video of the wee bike for now,but it works.First event with my latest
creation and everything went well.Looped it on the first section and thought this
was the start of it,then another 5 on a hillclimb (which I laid out :wall: ),then a
couple of 3's,then a few cleans.Don't know what my score was but I really don't
care as the wee bike performed well and is a huge improvement over the original
8x4.
Edited by broony
