October 5, 201511 yr Hi,I got myself a cheap TY 250 s 1988 recently and I am considering a full restoration. The frame has a number of lugs and mounting points that aren't being used and I need a bit of help idetifying what is missing. To make it easier, I've marked the points on these photos. I've had a look at some images and I think #1 and #10 are for a removable rear loop. I think #11 is a mounting point for the original exhaust.The rest I have no idea, any help would be great.Thankssam
October 5, 201511 yr 10 and11are exhaust mounting points I believe, 12 is a chain roller off the top if gage chain. 6and 7 are mounting points for the rear shock reservoir on my 1998. 9 is for the rear brake light from the light kit
October 5, 201511 yr Did the the S model not come with a battery fitted when new? i am sure the housing to carry it was located around the 2, 3, 4,and 5 points, a tool box was also fitted but this was mounted on the removable rear frame loop.
October 5, 201511 yr I had a 1988 TY250S new and agree with the previous posts, battery box was at points 2,3,4,5, but may not have used all of them, I am pretty sure all the parts removed at new, except horn, brake light switch and handlebar switch (used on a trail bike) are still in a box in the store shed, hope you do restore it, mine was probably the bike I most enjoyed riding and gave me some good results.
October 5, 201511 yr Author Thanks everyone you've been a massive help, the only photos I could find of the model from new were so small it was impossible to tell what anything was. dave_t I don't supposed you'd want to sell any parts you may have?
October 6, 201511 yr Give me a little time to make sure what I have got, I will let you know and we can take it from there.
October 7, 201511 yr 3 & 4 for battery bracket, 2 & 5 for battery cover now I have found parts, have sent you a message as I know we should not sell in forums, hope it has got to you ok
