October 12, 201511 yr Hi All does anybody out there know the diamensions of the kick start shaft oil seal mine leaks. Many Thanks Regards Chas
October 12, 201511 yr Are you able to remove and read number on front face? a good engineer would have fitted number facing out, so should be easy to cross reference
October 13, 201511 yr Author Thanks for the info, There is nothing on it not even a makers name,just wanted to order one up as this one will get destroyed getting it out to measure the case bore dia,shaft and seal width. Regards Chas
