November 8, 201511 yr Hi is any good cutting the case away round the gearbox sprocket to help with mud buildup round chain.thanks.
November 8, 201511 yr Fit chain tubes, rather than cutting casing, prevents chain jumping sprocket also
November 8, 201511 yr Casing cut away is a good idea. Done it on all my Mont twin shocks since the early 80s. If you take care with stitch drilling the shape 1st it's a doddle or I can do it for you no problem. I do away with the lower tube and fit a proper spring loaded tensioner. You still need the top tube to keep the crud off the chain to take the place of a standard style chain guard but trust me a plastic tube will NOT stop the chain wrapping round the front sprocket if it snaps or comes off the rear. I can show you another trick to stop that if you want. Can email pics of mine if you want.
November 8, 201511 yr Sorry Sprite125 Forgot contact info - email on martinet769@btinternet.com if you need to get in touch Ian
November 8, 201511 yr Author Hi if you can let me have any info on the cota 200 that will be great.thanks Arthur.
November 8, 201511 yr Author Hi if you can let me have any info on the cota 200 that will be great.thanks Arthur.my email address is arthurhemsworth@talktalk.net.ps you may have got this a few times but that's because I don't know what I am doing with this thing.
November 11, 201511 yr Casing cut away is a good idea. Done it on all my Mont twin shocks since the early 80s. If you take care with stitch drilling the shape 1st it's a doddle or I can do it for you no problem. I do away with the lower tube and fit a proper spring loaded tensioner. You still need the top tube to keep the crud off the chain to take the place of a standard style chain guard but trust me a plastic tube will NOT stop the chain wrapping round the front sprocket if it snaps or comes off the rear. I can show you another trick to stop that if you want. Can email pics of mine if you want. Hi Stannergas, Could you email me the pics if you would be as so kind? hardtofindtwinshocktrials@gmail.com Thank you, Mark
November 11, 201511 yr Author Hi Mark if you can let me have details of cutaway on case over gearbox sprocket and what you think is the best carb. Also what chain tensioner do you have on.i would like to talk to you.as you seem to know the 200montesa well any chance of a tel no? My no is 2821993 I am near leeds many thanks Arthur.
November 11, 201511 yr Hi Arthur, I will give you a ring later today, I am in Sheffield, so not a million miles from you. Cheers, Mark
