Starting Issue 2015 4Rt
I removed the Bank Sensor and the bike still would not start it was trying to start but just would not go, pulled the plug out and it was jet black and very sutty put a new plug in and it started 2nd kick. Hopefully all sorted now I'm think it was a mixture of freezing cold weather and a dodgy plug. I never knew the bike had a bank sensor so at least I've eliminated possible future problems.
Thanks for all your help
Edited by taff_d
4rt's are (mine was anyway) the most reliable starters out there.
Rule 1 dont adjust anything if its running ok.
Rule 2 if it doesnt start after 3 kicks reset and it then fires up next kick.
You should not be kicking it anymore than this.
(unless you have left the tilt sensor on)
Mine is the same
Never had a problem till Sunday, hopefully all cured with the new plug.
or put a freshly sprayed/oiled air filter in - they definitely don't like that!!!
