315R/2005 4Rt Swingarm
Can anyone tell me if a 315R and a 4rt swing arm are compatible
The 4rt in question is a 2005/6 model
Thanks in advance
Will only work on later 315's with inboard rear disc. If earlier 315 you will need to use wheel and brake assy from 4RT as well.
Unless you mean you want to use a 315 arm to go in a 4RT in which case you will need an arm from a late 315 (inboard disc caliper type)
Hope that makes sense...
Edited by lsv
Thanks for the reply, the swingarm available is from an early 315, so wont be suitable.
