samwisemcg Posted July 11, 2016 Share Posted July 11, 2016 I've got a bit of an issue with my 88 mono. It has trouble finding neutral. You think you have it, then it pops into 1st or 2nd. Any ideas? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
reggie Posted July 11, 2016 Share Posted July 11, 2016 Is this situation happening with the bike running ? If it happens when the bike is not running then this is not normal. If it is happening when the bike is running, this is common for a lot of bikes regardless of brand. You will find it may be easier to find neutral if the clutch lever is pulled all the way to the handlebar when you try to select neutral. 1 Quote Link to comment Share on other sites More sharing options...
samwisemcg Posted July 11, 2016 Author Share Posted July 11, 2016 It only ever happens with the engine off. Is this really normal? It makes moving the bike around a nightmare, plus also trying to start the bike when it won't stay in neutral is next to impossible.Thanks for the help. Quote Link to comment Share on other sites More sharing options...
reggie Posted July 11, 2016 Share Posted July 11, 2016 This is not normal, my best guess is that there is something wrong with the neutral detent mechanism. 1 Quote Link to comment Share on other sites More sharing options...
