September 1, 201610 yr Has anyone had the issue as I have had with the poor quality/design of the stock alloy mudguard stay fracturing? It seems a pretty bad idea to me to fold 3mm alloy almost at right angles and not expect it to crack. Weve welded it up before and added extra material in the affected area but it still keeps fracturing! grrrr thing is you cant fit one off an adult bike because it bolts on differently, 90 deg to the pro txt one. It has the paolli forks as on similar small bikes such as the beta 80. I can see me having to fabricate something better unless someone on here knows better?................
