November 11, 200521 yr Hi How much and what type of gearbox oil for a 50 mini trial auto please Appologies if this question has been asked i just can't find it in forum search
November 11, 200521 yr Any good gearbox oil ELF 4t , PJ 1, etc..uses approx 150 cc Edited November 11, 200521 yr by Ron
November 11, 200521 yr Funny I just got one of these, and talked to Beta USA about it this morning. Ron Sr. says: 150cc's of 10w30, and change often.
November 11, 200521 yr Author Thanks guys the replies on here are so fast and accurate i've just got a rev 50 minitrial seconhand 1st day out today. The kickstart siezed after a couple of hours turned out to be a circlip on the kickstart shaft had come loose behind kickstart and the kickstart gears misaligned themselves hence new oil needed
November 12, 200521 yr Author Thought you where maybe a tad to big for a beta 50 <{POST_SNAPBACK}> Taken John B's advice as i'm not riding the Mont too consistantly thought if i went to a 200 i would improve then decided if i went 50 auto i'd be transformed
February 14, 200620 yr About the oil in the auto clutch. Use 250mL of any Dexron III ATF in the clutch. If it runs hot due to throttle blipping by the rider, add Two2Cool. Ignore the 150mL written on the case.
