netley Posted October 20, 2016 Share Posted October 20, 2016 I have torque figures of 5 ft/lbs for both crank case bolts and crank seal holders. This seems little more than finger tight. Anyone have anything different? Quote Link to comment Share on other sites More sharing options...
trailie Posted October 20, 2016 Share Posted October 20, 2016 I would have reckoned probably 10-11 Nm (7-8 ft/lbs) would be about right for an M6 thread. 1 Quote Link to comment Share on other sites More sharing options...
bondy Posted October 21, 2016 Share Posted October 21, 2016 i just tighten them by hand never had a problem be carefull with the seal holders they can easy crack if done up to tight. 1 Quote Link to comment Share on other sites More sharing options...
twinnshock Posted October 21, 2016 Share Posted October 21, 2016 5 ft/lbs seems about right to me. Originally Bultaco used awful star locking washers that I hate. Others may have different opinions. I use plane washers, 5 ft/lbs and screw lock. Never had a issue with coming apart in use. I work on Diesel engine design for a day job and we calculate every joint to determine correct torque for application. (Part of design team on new Transit 2.0L engine "ECOBLUE" just launched) Apart from the obvious joints like head bolts etc most joints use a lot lower torque than you would at first think or do by feel alone. I have seen a lot of Bultaco cases with these threads stripped.Please not too tight. Stuart 5 Quote Link to comment Share on other sites More sharing options...
