Sherco 250 Breathing Oil Help! Please
Hi all I have a 2007 sherco 250 and was out riding the other day the bike started heavily smoking and breathing oil from the crank case I'm putting it down to crank
Seal on the clutch side? Question being is it a bad job is the seal on the outer side of the engine casing or is it full strip down ?
Any help would be greatly appreciated
Thanks Chris
Can be replaced with the engine in the frame still.
The clutch needs to come off to do it & a new clutch cover gasket is the only extra part that you really need although I would suggest replacing the water pump seals while the clutch cover is off
