January 27, 20179 yr OK I need some Gas Gas expert help. I've not opened it up yet and it may be a simple one but it's not one I've seen before. Today the clutch level started stopping well short of the handle bar. As I rode, it sometimes pulled all the way in and other times stoped well short even once almost fully out. When it's doing this and the engines not running I can hear the slave cylinder piston knocking against the case like somethings sticking it from extending to compress the clutch. Any ideas before I open it up? 2015 TXT Pro Racing 250cc
January 27, 20179 yr There is a small screw in the centre of the clitch basket which goes into the gear shaft. It works loose, and falls out, sometimes hitting the slave cylinder piston which causes your clutch lever to go solid half way in. It's an easy fix, just screw it back in, using Loctite. There is a breather hole through the serew so be careful not to over tighten it. I've heard that you can also take it out completely, and the clutch will be fine.
January 27, 20179 yr Author Yes that's my thinking just now too. I usually remove it and leave it out. Serves little purpose once the case is back on. Currently struggling to remove the kick start.
January 27, 20179 yr Take the kickstart screw out a few threads, and pivot the lever to push against the screw. It should slide out and off the spline. Edited January 27, 20179 yr by dabba
January 27, 20179 yr Author It's not my first time. On this occasion that trick didn't work. It's off now and the fault appears to be a sticky slave cylinder/piston.
