Kickstart
Went to start my TL320  the kickstart is not engaging i am only getting a clicking sound as it tries to engage. Does  anybody have any ideas.what has failed.
Then you might have an issue with the ratchet or the spring inside, I would guess the spring and may be too the tension of it.
Did you tried to change oil and accidently untightened the lowest screw underneath the motor?
