October 1, 20188 yr Hello everyone, I'm Matteo from Italy, I have a Ossa tr 280 of 2012, the bike is fine but I have a couple of problems to solve unfortunately in Italy there is nothing and there are no active forums, I need help I would need the kscan program and the explanation on how to build the connection cable in Italy it costs around 550 $ and the program is not found. can someone help me? I should also connect the front LED headlight but I do not have the switch on the handlebars, what are the cables to connect? I will put a hidden switch I apologize if my english is not perfect thanks a lot to everyone
October 1, 20188 yr Quick search on here found this:- Posted December 20, 2013 I was able to view the file on the Ossa USA site so it seems that the link has been fixed. http://www.ossausa.c...arts/tech-tips/ Quote
October 2, 20188 yr Author I have an update, from the bike I get only a red and a black cable and are connected to the capacitor, I have to connect there the led light?
October 2, 20188 yr Author Hi Rich, the site tells me that I can not send you messages send me a message with your email if can you
October 3, 20188 yr Ciao in origine la luce era collegata in modalita sempre accesa in zona canotto da qualche parte ci saranno i fili tagliati Edited October 3, 20188 yr by ossa68
October 4, 20188 yr Gobig if you go to page 2 of 33 and check tr280 software you will see were you can order a cable and how i hooked it up. I got my terminals and connectors from corsa techinic.com. The drivers should load when you plug in the cable.
October 5, 20188 yr PM me and I can get you the software. I have the parts to make two more cables- but I have not gotten around to it. I’ll try to get on it and make sure they work etc. Mark
October 5, 20188 yr Author thank you very much for all the help Papapitufo proceeded to send me the program and recommend the cable, I also solved the problem with the LED light. now I am cursing because the previous owner has glued the front wheel spindle?????
October 6, 20188 yr Ciao Gobig, I had the same problem with the front wheel spindle, the aluminium spindle had locked onto the bare steel spacer in between the wheel bearings. Make sure the fork slider lock bolts are loose, support the fork slider where the spindle would be removed from with a heavy piece of wood, then try tapping out the spindle with a hammer and brass or aluminium drift. Hopefully this will work. Ciao, Peter B.
