October 19, 20188 yr My Fantic 200 has been stood for 18 months (dry storage) before storage it started fine, now it doesn't start at all. It's got a very weak spark (very, very weak), done all the usual, new plug etc etc. On measuring the coil, 3 terminal alloy type, ones side has 55 ohms and the other has 714, earth to ground is zero, does this point to a duff coil? If so is the blue type that In Motion sells (£47) a worthwhile upgrade? Thanks.
