October 29, 20188 yr My 2003 txt300 died a while back, well more like a year or so ago. Lost its spark, checked the basics & sulked with it. Now winter is here so Id like to get it up and going again, although patience is running thin already!! Its got the "oh-so-reliable" Ducati ignition setup (joys). Stator is giving about 1ohm, spinning the motor over on the drill gives around 16-20v. Pickup is 242 ohm, so seems ok? Cannot really measure the output without an oscilloscope but the resistance checks out ok. Tried two reg/recs. It had a new one for the last issue which was a slow cooling fan. Wiring checks out Earths are all good. Looking like possibly the coil/cdi unit then? I did try one off an rs50 but no joy, more of a shot in the dark as it was £10 rather than £280 for a new GG one. Any other suggestions? kill switch is removed. If Im going down the route of a new coil/cdi then Id rather switch to a kokusan setup and be happy that it will last longer than the ducati stuff. Would anyone in the uk have some leads on where to get a complete setup? Otherwise Ill have to sell the thing as-is, or break it for spares.. Cheers Paul
October 30, 20188 yr you can test the coil/cdi using the values in this link. https://drive.google.com/file/d/0B0Mfile5Ahnmb2tvWHRRaWRBRUU/view Thanks to Hell Team Australia for the chart Edited October 30, 20188 yr by bluey
January 19, 20197 yr Author On 10/30/2018 at 7:47 PM, bluey said: you can test the coil/cdi using the values in this link. https://drive.google.com/file/d/0B0Mfile5Ahnmb2tvWHRRaWRBRUU/view Thanks to Hell Team Australia for the chart Thanks, Ive just been through that. Im getting similar readings on all wires apart from the red/white seems to be dead (nothing between that wire & any of the rest). Got a feeling thats just the wire for the kill switch?
January 19, 20197 yr Author Ive tried supplying 12v to the cdi as a last ditch attempt today, still nothing. Was a guess that the output from the reg/rec to the cdi was 12v..
January 19, 20197 yr my results were as below. Green x means close to spec Red x means no circuit After replacing the CDI the bike ran You can test the stator with values from this drawing https://drive.google.com/file/d/0B0Mfile5AhnmUUFCV1huenhQX0E/view
February 9, 20197 yr Author So, someone kindly send me a known-working cdi & still no spark. Bah. I did read somewhere that the pickup should send about .7vac to the cdi. Mine is doing .3 at best. Ill have to try that next, or send the stator away.
February 19, 20197 yr Author Just spoken to the rewind company, the stator itself was good but pickup was tested as knackered. Have purchased another off them & will report back once its arrived & fitted. Fingers crossed!
February 20, 20197 yr Author Well it all came back today, so rather excitedly I put it together, kicked over & still no spark. On either CDI. W@nk! Only had half a lunchbreak to look at it, hopefully I've missed something obvious. Otherwise not sure where to go next..
February 20, 20197 yr Author Had a good play with it earlier, turning over on a drill. Plenty of output from the stator. Pickup seems to be working ok. Bypassed the reg/rec. Still nothing. Its going on fire next.
February 20, 20197 yr I can't see in the previous posts. Have you changed the HT lead, plug cap and spark plug?
February 20, 20197 yr Author 7 minutes ago, richt said: I can't see in the previous posts. Have you changed the HT lead, plug cap and spark plug? Tried a different lead on the cdi. plug & cap are off so just lead to earth.
February 21, 20197 yr Author Further update, have given in & bought a complete kokusan setup. Expensive but worth it hopefully..
March 12, 20197 yr Author On 2/21/2019 at 3:38 PM, d2w said: For future reference, from whom did you buy it (if not a private sale)? Hi, RCM down in Redruth. Cracking bunch to deal with.
