Climber 280r magneto
Is that the correct plug for a climber ? Thopught most trials plugs had a projected nose, making them run hotter to burn the crap off. I'd check that first.
I'd go for a bp5es ngk
Edited by b40rt
Update ! I've ordered a brand new dellorto carb with recommend jet settings from the factory I'll let you know if that sorts it this week thanks for all your help so far
Edited by gasgasrob
Well, may be it's partly the carb and then most likely the jets and nozzels which where replaced by wrong elements or in wrong sizes.
A worn out carb can also be the case,especially the body which is too the cylinder and the slide, but that takes quite an effort or a wormn slide that has been used too long and rattled beside hiomself the cylinder too to oval shape ...
Can you tell us please your carb set up:
- slide number (on the bottom of the slide inprinted),
- needle, and needle position,
- needle nozzle,
- idle jet,
- main jet,
- float valve number
- choke jet,
I personal would recommend a NGK BP 5ES too...
  • 2 weeks later...
Update and fixed !!! I have fitted a brand new dellorto carb from euro carbs jetted and ready to fit and the bike now starts runs and rides like a new one ! Thank you for all the advise you guys !
I'll be in touch when it fooks up again which will probably be soon ?
Good news. Did you buy a petrol or air screw carb ?
Edited by b40rt
Petrol bud worked straight out the box
