300, Tame ? Or Insane ?
I have a 300ss, even changed out the tube for a fast one, it's pretty docile and torquey but it will do the business if you wanna clutch it up steps.
I have started with trials only a year ago; initially with an old 2008 Beta 270 rev3. After finding how much I enjoyed it, I faced the same dilemma. In the end I bought two months ago 2018 Beta Evo 300. Now, I cannot advise you on the capability of this 300cc bike as I am not jumping over high logs or boulders yet but: you can make it as fiery or docile as you want. I have not had a problem with bike running wild or scaring me. In my opinion as long as you have a good clutch and engine control using appropriate gear all bikes are easy ride.
I started in trials on a 300 Evo. You'll be fine. Put a slow throttle on it if your clutch/throttle control isn't great.
Changing the head insert can make a huge difference as well, my 2017 Factory 250 2T was a dog until i put the red s3 insert into it, best 90$ i ever spent. You can also add an extra base gasket as well to make it softer.
I’ve had two of the 300s and my experience matches mcman56’s  most closely. They can be made softer off the bottom with modifications. Proper jetting, gear down a bit, low compression head and carbon reeds on mine. Purrs like a kitten and grunts like a pig. But... it is still a 300 and will remind you of that fact if you get sloppy with the throttle. Lose focus and you better have a quick clutch finger. I haven’t tried super smooth but I have had Betas with added flywheel weight and I just don’t care for the run-on you get with a flywheel. I also like feeling for traction with a more responsive engine but to each their own.
I had a 40 year lay-off from trials bikes (all motorbikes actually) and was no great shakes back then either. I then got back into it 2 years ago. Now a few years off 60.
Started on a '07 250 GasGas, then a '13 290 Sherco and now a '17 Beta 300.
I ride C grade (one up from Clubman in Oz), thinking I might have a dabble at B grade and see if I can not embarrass myself too much. I suppose I'd describe myself as always willing to challenge my abilities, but with a solid aversion to hurting myself.
Moving from the 250 to the 290 was noticeable but not much of a step. I found it easier to ride a lot of things because it lugged at low revs a bit better when I got it  wrong.
Moving to the 300 was way more noticeable. I was a bit nervous moving to a 300 and wondered if it was a sensible move, but as you say there's a lot of good deals to be found in that category. It feels like it's got almost the same acceleration from stall as it has when it's singing. Grabbing a handful of throttle close to stall and it would take off. I'm not sure I've used full throttle for more than a second or two in the past 60 hours on it, and that would have been on open fire-road climbs purely to see what it felt like! Definitely earned my respect! That said ...
After say 10-20 hours on it I came to love that low down torque. It's just so forgiving of rolling off the throttle a bit early or being too cautious to hit something a bit harder, I can chug it along and when I twist the throttle it just picks up and responds, no fuss or bother. It's almost stall proof! I rarely use first gear, it's lower than either of the other two bikes - good for tight turny sections only - I can't imagine gearing it any lower! I know some people gear the Beta lower, then completely forget 1st and use 2nd and up. I find stock 2nd good for just about anything with a bit of clutch. Starting takes a definite jump on the lever (I'm 70kg), but my bike starts and idles first kick, no choke, no throttle every time so it's not a big deal.
As was said, someone at my level doesn't need a 300, but I'd have to say that it feels a bit like cheating riding it, and I'm happy to rely on superior machinery to make up for inferior skills.
So my thoughts are: It's definitely got a lot more "scare" bottled up inside than a smaller bike when things go bad. However if you're reasonably decent with the clutch then there's a pretty reliable get-out-of-gaol card. If you can get comfortable with the 300 then it actually makes riding easier I reckon - it feels to me that you need more skill to make a smaller bike really work. I also know (and can well understand it) that for some people the power of a 300 is simply a handicap - it can be scary how quick it accelerates, but for me once I got used to that and got some confidence that I could grab a handful of clutch and everything settled down, then that extra low down torque just makes everything easier.
I've still got both the GasGas & the Sherco but when I hop on them now they feel harder to ride than the Beta. Everyone tends to suggest having a ride on one, but my experience is mixed about that - a 15 minute ride left me thinking, "Wow, that thing can bite", but after a some hours I became quite comfortable (it seemed too good a deal to pass up at the time, so I got it despite that first experience). If you can get a good deal I'd say go for it, but if it doesn't feel right after a good few hours on it, sell it on and get something else, I can't imagine really liking it with a heavy flywheel or a slow throttle.
  • 3 weeks later...
