04 Txt Boy
hi guys hope you can help ive got a txt boy with no sign off a spark any ideas only got 1 grumpy 8 year old askin why carn,t you fix it dad any help appriciated
Hi, these super little bike`s are famous for their lack of spark, they had problems with the original stators in the earlier bikes but by upgrading it to the 05` ignition system it was supposed to rectify the problem. They use to run really well for a few hours and then stop, with no sign`s of life for the rest of the day, Gas Gas UK who are incredibly helpful (ask for Kev) say that the stator break`s down when they get hot, give them a ring and just check that the 05 stator has not been already fitted. You should be able to check if you look at the exit point of the wire through the casing, the standard fitment leaves at roughly a 7 o`clock position, the 05 version leaves at roughly 9. The new stator is around a hundred quid that`s the down side to , so make sure you check first, hope this is of some help,
regards
Howard
thxs howard talked to kev gguk about stator fitted one grt spark now but still wont start ? have another play tommo
Did you remember to move the fly wheel key to the other slot ??
Morning, yes the crank should have 2 slots cut for the `key`. because the new stator fits in a different rotational position the fly wheel key will want moving to the other slot to allow it to spark at the right time, hope it helps,
regards
Howard
many thxs howard its 50 boys going like new :) litte lad says Thanks too
Thats great news,I`m pleased that I could help, I will keep my eye out for him feature in the result table`s !!
take care
Howard
