February 7, 20206 yr I went to change my gearbox oil and noticed I’d bought dexron2 atf mineral, Is there a difference between dexron2 or dexron2 mineral or is it all mineral oil. I’m just wary it knackers the seals. Many thanks in advance folks
February 7, 20206 yr If using ATF I'd say much safer using Dexron III as it is higher grade. Never seen anyone using Dexron II
February 7, 20206 yr Not worth the risk,get the right stuff.Might be ok,if it's not you still need to buy the right oil,and repair the damage
February 8, 20206 yr I use dexron II in my txt pro I'm sure there's issues with the clutch and synthetic oil on the Gasgas, the clutch pack swells
February 8, 20206 yr 3 hours ago, suzuki250 said: I use dexron II in my txt pro I'm sure there's issues with the clutch and synthetic oil on the Gasgas, the clutch pack swells I thought it's ATF that swells the clutch plates,but if you're using it with no problems carry on.I always ran our Gassers on synthetic with no problems so I don't know the true answer
February 8, 20206 yr On 2/7/2020 at 3:13 PM, txt joker said: I went to change my gearbox oil and noticed I’d bought dexron2 atf mineral, Is there a difference between dexron2 or dexron2 mineral or is it all mineral oil. I’m just wary it knackers the seals. Many thanks in advance folks Joe Kerr ?
February 9, 20206 yr I use type F in mine(2015 300 pro)and never had a problem.I should see what the difference is in these oils I guess.
February 9, 20206 yr Gasgas put out a technical bulletin some years ago recommending ATF..I used to have a copy but I’m sure it’s still online somewhere
February 9, 20206 yr Found it online https://nanopdf.com/download/protechnicalbulletinusajuly222013_pdf#
February 9, 20206 yr Author 37 minutes ago, thall1 said: Found it online https://nanopdf.com/download/protechnicalbulletinusajuly222013_pdf# From reading that I should be using dexron3 thanks
February 10, 20206 yr Also use atf dexron 3 works great! Anybody idea after how many hours it's need to replace the oil?
February 11, 20206 yr Author 11 hours ago, Clanned said: Also use atf dexron 3 works great! Anybody idea after how many hours it's need to replace the oil? Hi Clanned,i try to change mine every 5 hours
February 11, 20206 yr 10 hours ago, txt joker said: Hi Clanned,i try to change mine every 5 hours It's atf, what happens in 5 hours in your bike ??
February 11, 20206 yr Author 8 minutes ago, b40rt said: It's atf, what happens in 5 hours in your bike ?? Canny answer that,I’m sure I read in another post in one of these forums to do it that regular
