April 25, 20206 yr The open spring side of the seal faces inward (the cranckcase). If the seals are fitted correctly, there could be a gasket problem, a crack in the case or the 'O' ring/s under the crankcase nuts and bolts are shot. Not at all easy to diagnose from a description. I'd go for a full stripdown. All of the parts are available.
