Fantic 240 clutch spur gear problem
IAN O’Keefe
Hi All,
As a new member to the site I am hoping someone can help me with a dilemma. I’m presently restoring a 240 pro and have just started stripping the motor down to find that the spur gear on the back of the clutch is badly worn. I understand it is a common problem on this engine, but does anyone have any solutions? It seems that the clutch basket is unobtainable? It would be a real shame that I have to stop the restoration here because of this issue, unless anyone out there has a good clutch basket they are willing to sell.
Comments and suggestions welcome.
Ian
Hi there  Ian.
So sorry I am new to this.
You can machine and fit A 300 onwards Gear which is pressed out
Machine  old gear off & machine & Weld 300 onwards  gear to to back of a worn out 240 basket I’ve done 50/60 over time.
hope this give you hope and to all other 240 owners with rattling clutches.
  • 5 years later...
Hi,
I have just discovered a similar problem with a badly worn kickstart gear on the back of my 240 clutch drum.
The fix posted by StevP 6 years ago sounds like a good solution, do you offer a service for this StevP?
Has anyone found a cost effective solution to this problem?
