November 10, 20206 yr I have a 2019 Vertigo Vertical 300 and I would like to try the 2020 Vertical 300 map. It would be great to compile a database of maps that the Vertigo owners can share and try. This forum allows the upload of the map file format. I found a good instruction video that is posted below. The WiGet app for the GET Ecu makes it very easy to share maps. I currently have these maps to share: 2020 R2 300 2019 Vertical 300 I will update the list and post the maps here as I get more Thanks, DT Edited November 12, 20205 yr by Chukarhunter To help users get accurate information since file posting rules have changed.
November 10, 20206 yr What is the file format and how big are the files? If they present no security risk and aren't too big I could allow them.
November 10, 20206 yr Author It is a .pro file Example file format: Ecu Map @RX1VTG07.pro It looks like they are about 1340 bytes. Here is a video about how the files are created and shared. It is in Spanish but it the steps are easy to follow. ie
November 12, 20205 yr Author Here is the 2019 Vertical 300 2019 vertical 300 Factory Map@RX1VTG07.pro
November 13, 20205 yr Thanks for the maps .. Do you all use the wificom to connect with bluetooth or are there other devices? I am undecided whether to buy it or not since it costs very little.
November 14, 20205 yr Author I used the wificom device to download the maps. I think it is worth having in your tool kit for playing with maps. The WIFICOM device lets you calibrate the TPS and check diagnostic trouble codes if you ever experience any problems.
November 17, 20205 yr Thank you ... Ordered now, I hope I get something and it works because I ordered it at a bargain price from another continent
November 24, 20205 yr Author On 11/17/2020 at 3:53 AM, Simonelongus said: Thank you ... Ordered now, I hope I get something and it works because I ordered it at a bargain price from another continent What Vertigo do you have?
November 24, 20205 yr I have a slightly prepared 2018, I don't know what, I bought it like this ... it has a titanium exhaust and the head has been modified and I don't know the mapping.
November 26, 20205 yr On 11/12/2020 at 6:17 AM, Chukarhunter said: 2020 r2 300 map 2020 R2 300 factory map@RX1VTG07.pro 1.32 kB · 26 downloads Hi how do you get it from hear to the WiFi app thanks
November 30, 20205 yr I was wondering in the 2018 model there is no switch to change the mappings like on the other models. Is it possible to put a switch also in 2018? As was done for the Bones, it was enough to switch 2 pins
November 30, 20205 yr Author On 11/26/2020 at 12:58 PM, Robert n said: Hi how do you get it from hear to the WiFi app thanks In the app, select the map factory map, hit the three dots; and select "copy to custom maps", then find the factory map in the custom map list, hit the three dots again and select "share the map", then send the map to your computer by email, then save the file from the email to your computer, and then post the map here by just dragging it to the reply when you post. The video above shows how to share the maps. Thanks
December 1, 20205 yr On 11/30/2020 at 9:35 PM, Chukarhunter said: In the app, select the map factory map, hit the three dots; and select "copy to custom maps", then find the factory map in the custom map list, hit the three dots again and select "share the map", then send the map to your computer by email, then save the file from the email to your computer, and then post the map here by just dragging it to the reply when you post. The video above shows how to share the maps. Thanks Thankyou I only have a phone with the app on carnt do the computer bit as I don’t have one It’s saved on the phone somewhere I’ll give the three dots a try ?
