January 10, 20215 yr Excellent idea , I have just purchased a WiFi box , and downloaded your maps. Will try them out when i get the box fitted. And will try to upload the standard maps for my 2020 250 Vertical Combat. Cheers
January 12, 20215 yr I have my wifi box up and running now . I can share the maps , But how do you upload the maps on to App. Here is my Standard map off my 2020 250 Vertigo Vertical.. 2020 Vertcal FLAT_0@RX1VTG05.pro
January 16, 20215 yr On 1/12/2021 at 7:14 PM, fastbike666 said: I have my wifi box up and running now . I can share the maps , But how do you upload the maps on to App. Here is my Standard map off my 2020 250 Vertigo Vertical.. 2020 Vertcal FLAT_0@RX1VTG05.pro 1.46 kB · 3 downloads I downloaded it too my phone and it had automatically gone on to the app but i had to do it near the house so it would pick the wifi off the house first to update the app when the bike was running it wouldn't do it out in the field
January 16, 20215 yr On 11/12/2020 at 6:17 AM, Chukarhunter said: 2020 r2 300 map 2020 R2 300 factory map@RX1VTG07.pro 1.32 kB · 49 downloads Got it to work thankyou ?
April 10, 20215 yr So have I have the Vertigo combat 2018. Installed the wifi module. I can see the tps, diagnostics etc, but loading the different maps I downloaded from here seems to have no effect. If I adjust a map, when I upload it to the cpu, then restart the bike, it appears that it is back to stock. Am I missing something, is there a way I have to "switch" to my custom map? Thanks, Dave
April 14, 20215 yr On 4/10/2021 at 4:50 AM, daveblackburn said: So have I have the Vertigo combat 2018. Installed the wifi module. I can see the tps, diagnostics etc, but loading the different maps I downloaded from here seems to have no effect. If I adjust a map, when I upload it to the cpu, then restart the bike, it appears that it is back to stock. Am I missing something, is there a way I have to "switch" to my custom map? Thanks, Dave I watched the videos on YouTube to see how it works and how to seperate the maps then download it of hear to my phone it went straight on to the app and just installed from there
May 31, 20215 yr Anyone have wet mapping or very soft mapping to use the Vertigo? I tried the Gas Gases and they are much easier. I tried to do it with the software but it creates too much vacuum in the first part of the throttle, and then I think that one made by the house is designed to make the engine run better.
July 28, 20215 yr On 11/26/2020 at 12:58 PM, Robert n said: Hi how do you get it from hear to the WiFi app thanks The shared map file is in my email. So I tap on the shared map file in my email on my iPhone, then I hit the "send to" option, and then select the GET app. Then the shared map appears in the Custom Maps list in the GET app. REPLY
May 23, 20233 yr Hi, I have a 2019 vertigo 250, can anybody advise me on how to change the map, thank in advance
