August 29, 20214 yr Hey, I am looking to update my kid’s 12.5 Oset to the next (16) size. I hope this is an okay subforum to post this question. Anyway, I initially was looking for the Oset 16 bikes, but then I noticed there are some alternatives. Beta has their minitrail, Mecatechno has something. Maybe some more alternatives. My question is, how do they compare to each other? Here, where I live Oset is for sure the most popular, but a few hundred more expensive than Beta is (new), Mecatechno not sure is available locally. As far as I understand all still come with acid batteries, or are there any that are already with the LiPo available out of the store?
August 29, 20214 yr For what it is worth we had an Oset 12.5, an Oset 16 and a Beta 16 Minitrial. Many of the components are identical, throttle, charger, batteries... Oset 16 has a pentiometer much like the 12.5 while the Beta has a 3 speed switch, real slow, progressively faster and fast. I liked the Oset tires and pentiometer more although both bikes were cranked up to full speed after the first 10 minutes, but possibly liked the beta suspension a touch more. Beta had hydraulic mountain bike brakes and I recall the Oset having cable disk brakes. I would recommend either bike, get your kid on one as fast as you can because before you know it you will be onto bigger faster more expensive ones (from my experience)
August 30, 20214 yr Author 10 hours ago, Glayne said: ... before you know it you will be onto bigger faster more expensive ones (from my experience) That is so very true :). Thanks for input!
