Beta Evo 200 ruined.
On 12/9/2021 at 1:13 PM, nhuskys said:
I put the Beta Accessory Heavy Flywheel on my '21 Factory 200. This is the same as a 300 Super Smooth or GB spec 250 flywheel. I'm very happy with improvement in how the bike works.
Where did you get the heavy flywheel,
I can’t see it listed on Beta uk s website?
Also did you need a spacer for the cover
thanks
I had a 250 with the GB spec flywheel weight. I always fancied trying the bike with it removed but figured that Lampkins knew better than me, so if they think it's a good idea, it's a good idea.
My only gripe was the horribly clunky up changes. As I closed the throttle between gears, the bike would slow down faster than the engine so it would never synchronise. It helped to always change gear (up) on a downslope and preferably a hard surface.
thanks
No.
  • 2 weeks later...
On 12/8/2021 at 12:01 AM, RogueGeek said:
Has anyone tried putting a 250 flywheel on the newer 200?  And noted the weight difference?  Thanks!
BVM know about this modification.
I’ve just fitted the heavy fly wheel 1lb 10 oz heavier than my standard fly wheel factory 200
