February 15, 200620 yr Has anyone had any experience using this product on their pro if so what were your findings anyone know what the torque settings are for the cylinder head on the 05 250 pro ?. Thanks H..
February 15, 200620 yr What do they actually do R2 and the fly wheel weight does it make the bike lighter??
February 15, 200620 yr Could you quickly point out to me what the difference is with these throttles, i understand that a slow action will be just that slow action ! lol but what does it do
February 15, 200620 yr my bikes running with a slow action throttle R2 still pretty wick but i like it like that suppose but if changing the flywheel weight will help grip in the mud then i might change it.
February 17, 200620 yr Could you quickly point out to me what the difference is with these throttles,i understand that a slow action will be just that slow action ! lol but what does it do <{POST_SNAPBACK}> I've got the black throttle tube on my 280 Pro. I found the throttle response with the white one pretty wicked for my meager trials skills. It helped me a lot. It changes the rotation from 96? to 124degrees, so it needs more twist to get it wide open, but its the off idle control it really helps with. You can dial in the rpm you need much easier. I was getting ready to try other mods like a head spacer or ignition timing, but I think its fine now for me.
February 17, 200620 yr Author Torque wrench setting for cylinder head bolts is 12Nm according to kev at Gas Gas UK. Thanks Kev..
