February 10, 20224 yr Does any one know if the older style guards pre 2019 fit the newer 301rr as with my stuffed hips im strugling to clear the leg over.Not to worried about having to trim it at the tank.
February 10, 20224 yr HI - No -at least not as a bolt straight on Tank height is different, spacer under the seat is different as is he little mudguard support at the back, If you changed te rubber and mudguard support you could maybe work around the tank? I looked when i had my 301 so I could use my old mudguards for precative and wanted quack swap back to new -maybe as a permanent mod might less involved
