July 31, 20233 yr Hi I am looking for advice regarding the amount of free side play at the side of the big end between the big end and the Crank flywheel. I have just pressed in a new crank pin and the width across the flywheel is the same as the width before I rebuilt it, at the moment the side play on the big end is 0.3mm(0.012in). I would be grateful if anyone could let me know if this is ok or if they have a workshop manual what the min/max tolerances are. Many Thanks.
July 31, 20233 yr Hi 70'sRider - Hope the attached will help on the rebuild, pretty sure it does specify the max big end float - Thanks Paul Fantic 200 FM350 Rebuild Man.pdf
