Gremclon Posted February 6, 2024 Share Posted February 6, 2024 Hi Lads, Just wondering if you could help. I'm looking for a fan rectifier for a Scorpa sy 250. Fan works directly from 12v battery and thermostat works fine. Just wondering if you had something suitable. Also need a rear brake master cylinder. I'm based in Ireland Thanks a million it's a 1998 Emlyn Quote Link to comment Share on other sites More sharing options...
lemur Posted February 6, 2024 Share Posted February 6, 2024 Hey Emlyn, I had one of those once, had to rewind the alternator coils when it burned out. The 12 volt rectifier you need is nothing special you can use one from almost any similar motorcycle, same with your rear brake master cylinder, should not be difficult to source either of those items. Worst feature of the bike is the air intake doesn't like deep water crossings, that's what eventually killed mine, try not to drown it. Quote Link to comment Share on other sites More sharing options...
